Home > Technical > Limp home mode! |
GARYF123 Member Since: 03 Jan 2015 Location: leeds Posts: 143 |
My 2007 2.7 TDV6 has a tendency to loose power every now and then. No real pattern but very unnerving! The restricted message pops up and i have to pull over and switch ignition off then on again and all is well until the next time. I had the codes read and i think it was P0117E, fuel pressure fault?
Sun Sep 20 2020 8:13am |
Apologies, it was P117E - Fuel volume regulator control exceeded minimum controllimit. |
Sun Sep 20 2020 11:08am |
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 |
If I recall correctly from when I had my 05 2.7tdv6 Disco 3...the high pressure fuel pump is at the back of the engine. Requires removal of auxiliary belt.and associated pipe/s unbolt the old and bolt on the new one, reconnect pipe/s and aux belt. The labour was reasonable..at around £120 or so..( I am talking almost 8 years ago)...but the high pressure fuel pump was expensive at just over £800...though again that was in 2012. Mine had to be replaced due to leak. Hope u get it sorted. |
Sun Sep 20 2020 11:53am |
