Home > General > Tdv8 multiple warnings on dash |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Battery connection ok?
Fri Sep 18 2020 9:55am |
rrsade Member Since: 14 Sep 2020 Location: swansea Posts: 13 |
Thanks for reply ,
Fri Sep 18 2020 10:45am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
Check the battery voltage when it's been stood for several hours - preferably 24hr - as this allows surface charge on the plates to dissipate and gives more correct reading. Then check the voltage with the engine running.
Fri Sep 18 2020 10:55am |
Ok cheers guys,
Fri Sep 18 2020 11:13am |
Sounds like a good place to start if it's only done short journeys since you bought it. 2012 SDV6 - it's missing a couple of cylinders
Fri Sep 18 2020 12:42pm |
Batteries hate short trips..as do DPFs
Fri Sep 18 2020 1:05pm |
I don't think the TDV8 was ever fitted with DPF in the UK. Could be wrong though. 2012 SDV6 - it's missing a couple of cylinders
Fri Sep 18 2020 2:12pm |
hi finally got around to testing the battery and getting reading of 12.03 when off and standing and 14.69 when running,so 12.03 seems low to me ? bearing in mind it had a long 250mile round trip 5days ago do you think it could be due a new battery if so what batteries are people using
Sat Sep 26 2020 4:21pm |
Maybe get the battery drop tested at a garage for peace of mind. I’ll be changing mine out in 2021 as part of preventative maintenance.... Visitor from fullfatrr.com
Sat Sep 26 2020 5:37pm |
Think i will change it for new one to be sure,
Sat Sep 26 2020 5:49pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5013 |
Don't bother with the 020 it's about 40mm longer than the original 019 and a tight squeeze to get it fitted correctly without pushing some wiring out of the way I tried it, the extra amps won't make that much difference anyway.
Sat Sep 26 2020 8:49pm |
ok thanks for the info
Sun Sep 27 2020 8:58am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
Should I be mentioning the Brake Light Switch? Its a quick and cheap job to replace and has been known to create all sort of weird electrical gremlins when it starts playing up. As do cheap brake light bulbs.
Sun Sep 27 2020 10:49am |
yes got a switch ordered ,checked the battery after being sat over night and it was down to 11.6 volts so guess it needs a new one, all bulbs are led so not sure if that got anything to do with it ?,but was getting messages of
Sun Sep 27 2020 12:42pm |
