![]() | Home > Tips & Tricks > Battery charge connector point |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Hi folks
teldec Member Since: 29 Dec 2019 Location: essex Posts: 80 ![]() ![]() |
If you have a tow bar then you can buy a ctek to 13 pin adapter, thats what i have purchased from here, https://www.disco3.co.uk/shop/charge-adapter-p45.html |
I think the thick wire green wire with brown stripe is power.
You can modify the ctek connector so that if you did forget to unplug it then it would just pull straight out, also you have the ctek warning card that you put on your dash to help prevent it also |
Thanks Andy K, I guess splicing into a loom was inevitable, I was just hoping there may be another way. I'll check the wire colour on the rear pins which should confirm things. I suppose a decent splice on the tow socket loom in a sheltered from water place shouldn't be so bad, at least it'd not be on a non replaceable loom.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5062 ![]() ![]() ![]() |
You could splice into the trailer socket wiring harness behind the N/S rear light, save dropping the bumper or removing n/s boot trim panel. Seem to remember the battery feed from Fuse 48 to the trailer socket maybe Blue/Pink.
May or may not be of interest but noticed this the other day, easy enough to make up yourself I guess though.
That ready made connector would do the job, although it's a pity they've used the traffic light connector as other than it being useless anyway, I can't think why as when charging it'd always be showing green. I guess someone might think it handy as a quick connect battery check, but it'd just show red when the battery was fine.
The full L/R kit for a MY13 is VPLST0071 as I fitted one to mine as managed to get brand new one of fleabay for £65.00. That harness certainly look very similar to the one in the kit with the 3 connectors though. If it helps at all I actually kept the original blanking plugs used from the harness already behind bumper when I fitted mine, plugs look the same. Also the engineering number 4H22-14A341-CA shown on the tag in the picture is exactly same number as tag on mine.
Col |
Thanks Col, that's it ordered so hopefully I'll finally get this done next week when the socket arrives. 13MY Range Rover Sport Autobiography SDV6 - mine
