![]() | Home > Wheels & Tyres > Goodyear Wrangler Duratrac 255/65/19 or 255/55/19 |
robtheranter Member Since: 05 Sep 2020 Location: Scottish Borders Posts: 10 ![]() ![]() ![]() |
New to this so be gentle.
andyslandy Member Since: 20 Oct 2019 Location: Chesterfield Posts: 142 ![]() ![]() ![]() |
I have driven 255 55 19’s Duratracs on and off road with no problems or adjustments at all and was just fine.. |
The cars a RRS it's only the 19in rims that are from a disco 3 |
I think the 255/55/19, are the standard winter tyre size and come in at 30in total diameter and the 255/65/19 are 2in bigger at 32in hence the 2in lift.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9025 ![]() ![]() ![]() |
255/55/19 was never a standard RRS size at all. Only the G4s had that size. Standard size is 255/50/19. 255/55/19 was the size on the Disco.
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
I'm running 275/55R20s which are minimally smaller than the 255/65/19s.
Glad to hear I'm on the right track, I didn't think I would have problem with the back I've been so fixated on the front, i'll get the tape out and double check . With the 50mm lift engaged everything seems to be ok with the 32in wheels but its great to hear from someone with first hand experience. |
If I was wanting to build an RRS for predominantly off road use, I'd go with 18 inch rims and BF Goodrich KO2 in 265/60/18. |
Tried and failed to go down the 18in rim route.
Another option would be to stick with 20s and use the 275/55R20s I have. They are a number of options available including the KO2.
Thanks for that,
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 ![]() ![]() |
There's some on the D3 site right now for less than 1K 2012 SDV6 HSE (technically its hers) 2000 D2 TD5 - definitely mine 2005 D3 V8 Metalian Camper trailer for adventures |
Tried the car with the 50mm lift for a couple of weeks with the original 20" wheels and 275/40s just to see if it was ok and I can honestly say it feels awful.
Good combination of 255/55/19. Have run the same set of Duratracs for the last 35K miles. All down to around 5mm now with regular rotations front to back and i have noticed they are starting to wear alot faster now so i will change them all before Winter arrives. In that time i have had one puncture.
