Home > Technical > Help with stereo connections
Joe Hankey
England 2006 Range Rover Sport TDV6 HSE Bonatti Grey
So sorry for this but unfortunately I have been very I'll and in hospital. I'm now home and need to know the size of the aerial wire and connections to make the wire joined together. So it will be longer. Then the connection for the back of the stereo. I will up load photos.. I do hope that this can help you to assist me. The garage has told me that thay will fit them for me if I can get the 3 fittings and wire.
This is one online and a aerial connection to the stereo. Just hope these photos are of help. It's to put back the original stereo.
If anyone could give me sizes of fitting and aerial wire this would help me and where to buy them.
Post #604099 Thu Sep 03 2020 12:27pm
Are you trying to fit an aftermarket stereo ?
https://rover.ebay.com/rover/0/0/0?mpre=ht...2507707267
https://rover.ebay.com/rover/0/0/0?mpre=ht...1410101390
https://rover.ebay.com/rover/0/0/0?mpre=ht...1385943393
Post #604123 Thu Sep 03 2020 7:55pm
Joe Hankey
No. Just fit the one we have. As the aerial connection has been damaged. We need a new replacement connection and the one on has to be replaced with a straight one to length the aerial wire. I do hope that you understand this.
Post #604125 Thu Sep 03 2020 9:17pm
Is it not just one of these you need. Have a look through this lot sure you will find what you are looking for.
https://www.amazon.co.uk/s?k=fakra&ref=nb_sb_noss_1
Post #604126 Thu Sep 03 2020 9:34pm
Joe Hankey
Help with stereo
We need to make the wire long and then a new connection. Thankyou
Post #604133 Fri Sep 04 2020 9:26am
idi
You could buy the connector Col has posted above, connect that to your current short cable and then buy a fakra extension cable.
Post #604137 Fri Sep 04 2020 10:25am
Joe Hankey
Help with stereo
Thankyou very much.
Post #604139 Fri Sep 04 2020 10:30am
If you do buy the connectors and or extension leads make sure they are the Aqua Blue colour connector as in the picture, they are universal and will fit to any of the fakra connector colours as your connector on the back of the audio unit appears to be black. Unless they have changed the design black will only match black, green match green etc. You could actualy leave the outer coloured part off and use any one, unlikely they would vibrate off, but to me personally that is the typical half a job.
Post #604153 Fri Sep 04 2020 9:17pm
Joe Hankey
Stereo help
Thankyou very much I will buy this one.
Post #604257 Mon Sep 07 2020 11:24am
