Home > General > Paranoid!!?? |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
I would be absolutely reassured that it could run on 750 ml of oil. Think of the savings! L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Thu Aug 27 2020 7:49pm |
ptaroni Member Since: 02 Aug 2020 Location: leicestershire Posts: 8 |
Exactly! He last had it serviced in may 2018 and never checked the oil since! It does make you wonder how many failures are down to lack of oil! Just fail to believe that the car doesn’t show any low level warnings for oil but it does when you check it with the dash menu! |
Thu Aug 27 2020 8:13pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4401 |
https://www.rrsport.co.uk/forum/topic56744.html
Thu Aug 27 2020 8:20pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4977 |
27 months with out checking the oil, I think this is a classic case of the dipstick behind the steering wheel being the problem, not the vehicle itself.
Thu Aug 27 2020 8:47pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8985 |
The service interval is given in time and miles for a good reason... 2012 SDV6 - it's missing a couple of cylinders
Thu Aug 27 2020 10:34pm |
Rusty Ranger Member Since: 03 Jan 2020 Location: East Sussex Posts: 61 |
Many cars have 2 years between services these days, don't they? I don't know about this car, though. 27 is not much more than 24.
Thu Aug 27 2020 10:57pm |
2 years between services is one thing, 2 years plus without checking oil level is just simply stupidity.
Thu Aug 27 2020 11:06pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
Surely with only 750ml of oil in the engine the oil pressure light would be on all the time or a least sometimes.
Fri Aug 28 2020 2:24am |
LRs are all on 12 month maximum time interval with a max mileage as well. Mileage intervals are shortened where less favourable conditions of use exist. I too would expect a low oil warning from any car made in the last 50 years or more. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Aug 28 2020 6:56am |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 |
Does the sensor work, may pay on services when oil is being changed is to ask them to check that it works with half then at empty? |
Fri Aug 28 2020 2:17pm |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
its better to check atleast once every 2 weeks due to the fact oil leaks and consumption occur all the time |
Fri Aug 28 2020 6:54pm |
Is the oil light on these vehicles not primarily a low oil pressure warning light, not a low oil level light to top it up as by then the damage could have been done. When doing a oil change on the facelift Sports and I assume the D4 as well L/R state on both the Maintenance Schedule and Vehicle Inspection Sheet as well as the W/Shop Manual to reset the oil level indicator on these vehicles, which I rightly or wrongly assume is a recalibration of it due to having the oil changed, this is done via the menu and cruise control buttons, just wondered if this is not done could it possibly give a false level reading? saying the level is o.k. when it is actualy low. I know L/R do complicate things somewhat but why would the dedicate several pages in the Workshop Manual to this if it was not necessary. If it is actualy necessary do some garages even know it should be done, just bring back the old dipstick, no problem then.
Fri Aug 28 2020 8:38pm |
The sensor worked when checking it on the dash through the menu! Said below minimum ... I’m just really surprised that they don’t flag up when they go below minimum like most other manufacturers! |
Sun Aug 30 2020 8:04pm |
