![]() | Home > Technical > alternator killing sockets |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4424 ![]() ![]() ![]() |
ARC pump needs removed. Can't access both lower bolts with it in place... |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
Am confused. I've removed both lower bolts, they were a doddle. What's screwing me was upper bolt. Nothings blocking the lower bolts for me |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Oh you got a petrol
ah ive been using socket and 3/8. the video was just my last attempt with 13mm rachet spanner because the bolt has broken 3 13mm sockets already
I always just assume its a diesel we are talking about |
ahh fair enough explains why my ace pump isnt in the way |
Longer breaker bar. 1/2ā to 3/8 adaptor.
I've got some impact 13mm that'll hopefully take the strain. I've got a pipe that I use as a breaker bar so we'll see |
Smashed it, draper impact socket did the trick. I also think I made it harder for myself by removing the two bottom bolts first because then all the weight was on the top bolt. |
