Home > Technical > How to change radiator on range rover sport tdv8 3,6
Iremus
Romania 2009 Range Rover Sport TDV8 HSE Alaska White
Hello Guys,
I am new here but been reading comunity posts for the last years or so since I own a range rover sport.
Besida usual problems like suspension compresor, AC compresor and maintenance i didnt have too much issues with it.
Recently though my radiator started to leak so I decided to change it "myself"
Now the car lays in the garage with front bumper off, headlights and most of the front part, wheels and plastic protection on wheels but I still can't remove the radiator.
Any info in what steps to take to remove it ? I disconected all the hoses from radiator/intercooler, unscrwed most of the bolts/screws above/under radiator... but still i can't seem to remove it.
Is there something I need to do ? Should I also disconect AC radiator and try to remove them all together ?
Any info is appreciated.
Thank You
Post #603882 Fri Aug 28 2020 5:20pm
Normally you would remove the fan front the engine (difficult)
Tie the AirCon rad up with long cable ties
Remove its bolts and unslot it
And remove the rad from the engine bay side
Post #603884 Fri Aug 28 2020 6:00pm
Iremus
Yes Fan is removed also, cant seem to find that one bolt from engine bay side that needs removal, will look more tomorrow.
Post #603885 Fri Aug 28 2020 6:41pm
