Home > Technical > Limited gears
Page 4 of 4 <1234
DerrekL
Ok good to know, I've not tackled a gearbox on this scale before so every little helps Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #603661 Sun Aug 23 2020 7:26pm
DerrekL
Ok I'm questioning myself now...
Should I be fitting the TC into the gearbox first ? Then fitting the gearbox and TC as one unit ?
Or...
Should I fit the TC to the flywheel first then fit the gearbox ?
Also, I have fitted the top centre exhaust bracket to the gearbox first but it seems to be catching the soundproofing on the ceiling of the gearbox tunnel, is this ok to keep going with the fitting of the gearbox, should it squeeze past this ?
P38 4.6 HSE V8
Post #603755 Tue Aug 25 2020 12:09pm
I think it's normal to fit the TC to the gearbox first.
Regarding the bracket, I don't know. If it's causing a problem, best to remove it.
Post #603756 Tue Aug 25 2020 1:01pm
DerrekL
Gearbox fitted but still getting the F limited gears.
I haven't taken it out on a run yet, but believe I now need to flash the new gearbox ecu, is that correct?
I've also emailed GAP Team to ask their advice.
My question is, will this limited gears error be deleted once the gearbox is flashed ?
Or does it not look good for the gearbox I've just fitted Big Cry ?
P38 4.6 HSE V8
Post #605036 Tue Sep 29 2020 5:43pm
I wouldn’t worry just yet.
Get it flashed with your vin
Post #605037 Tue Sep 29 2020 5:56pm
Page 4 of 4 <1234
