![]() | Home > Technical > Limited gears |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 ![]() ![]() ![]() |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Yeah
Contraption set-up to pull out and drop gearbox, the gearbox has came away from the engine by few inches, question is where should I support the engine about, I think I screwed up by not chalking up the engine first, how do I know the gearbox has actually safely cleared the engine, is there a spline sticking out the engine or gearbox ?
I think you need at least 6 inches gap.
Ok thanks Andy I'm just about to give it another go |
Gearbox is out now. It is a 500570 model, do I strictly have to swap like for like ? As I do see 500460 on other similar aged gearboxes, on eBay ?
Well done |
Thanks Andy, was a relief to get it on the ground |
Yes. Can be done with iid and support from pat at gap
Superb thanks Andy |
Putting things back together now....
Sorry. I’ve not done it before.
Thanks Andy
That’s fine. Sounds like you have it covered |
