Home > General > Replace one turbo or both? |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 |
My drivers side turbo went pop on Saturday @ 107K miles. Oh well I got away with it for 10 years of ownership
Mon Aug 10 2020 7:39am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
My main interest in your post is that I guess that, more sooner than later, I'll have to have this job done, I can't speak with any knowledge to answer your question, but my gut feeling is that if you're going to have the body off, you should attempt to do everything you can afford to do. Certainly I'd do both turbos - if ones gone the other cant be far behind. There's probably other stuff that could be looked at???
Mon Aug 10 2020 8:58am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
At that age, I'd just replace both and be done with it. Be very annoying to get one done and then have the other one fail a few thousand miles later. 2012 SDV6 - it's missing a couple of cylinders
Mon Aug 10 2020 12:11pm |
Thanks all, car has just left me on the back of a transporter to the garage.
Mon Aug 10 2020 12:42pm |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
am a bit curious, why do turbos cost so much? is it because its a body off job and that takes a while? i mean after the bodies off i assume you just bolt off the old turbos and bolt on new ones? am completely oblivious to how the jobs done so feel free to treat me like a moron |
Mon Aug 10 2020 1:22pm |
Good question. I am sure the experts will come back with an answer, but I guess and element of it will be just that its a Range Rover! Robin
Mon Aug 10 2020 1:25pm |
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 |
Would be worth checking the condition of the Active roll bar pipework too when the body is off. 2010 TDV8 - current - my first RRS, loving it so far......
Mon Aug 10 2020 2:06pm |
The turbos are around a grand each so that £2k before you've started. Then it's a couple of hours plus each way to take the body off and replace it. That's a few hundred more depending on garage and hourly rates, obviously. Then chuck in the VAT and any bits that need to be renewed in the strip down and rebuild and you're up to £3k and more quite easily. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Mon Aug 10 2020 2:54pm |
For a grand each I think I'd use the opportunity to upgrade :p |
Mon Aug 10 2020 5:22pm |
Upgrade? 2012 SDV6 - it's missing a couple of cylinders
Mon Aug 10 2020 8:04pm |
Yeah I'd assume some better turbo to stick on :p |
Tue Aug 11 2020 1:14pm |
Car back from AJ Land Rover and all good Lets hope the new turbos last as long as first pair
Fri Aug 21 2020 8:09pm |
