Home > Technical > Limited gears |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4980 |
Well you need a replacement gearbox
Sat Aug 01 2020 8:43pm |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 |
Thanks for the feedback Andy
Thu Aug 06 2020 11:57am |
Yeah it's probably the gearbox.
Thu Aug 06 2020 12:20pm |
Nice one Andy thanks for that, might be something I could do.
Thu Aug 06 2020 1:29pm |
I've not done it yet, so not a lot to add ATM |
Thu Aug 06 2020 4:49pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8999 |
Sounds like the torque converter clutch is done for. That can be replaced as an item if you wish. The problem with buying a second hand gearbox is that it might be not far off being rubbish too. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Aug 06 2020 5:41pm |
Thanks Andy, if you find anything else, please let me know...
Fri Aug 07 2020 12:09pm |
Gearbox needs to come out to replace TC as it's in the middle between engine and gearbox
Fri Aug 07 2020 1:02pm |
The TC clutch is within the TC housing so you get a new one when you replace the TC.
Superb!! short and to the point, just how it should be, thanks again guys
Fri Aug 07 2020 1:58pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4409 |
New gearbox time
Fri Aug 07 2020 3:14pm |
You may as well use your existing transfer box as it’s known good.
Fri Aug 07 2020 3:50pm |
Thanks for all the info guys, at least now I have an idea of what route to go down, and thanks for chipping in Mikey, much appreciated
Fri Aug 07 2020 4:59pm |
Ok plan is to drop the gearbox at least.
Tue Aug 11 2020 8:54pm |
