Home > Technical > Standard calibration in MM ride height |
Apples24 Member Since: 04 Aug 2020 Location: Southampton Posts: 5 |
Success managed to lower it a tad
Wed Aug 05 2020 11:13am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
462mm front, 463mm rear That's measured from the middle of the centre cap, vertically, to the arch. When you run the calibration routine, you adjust each corner until all corners are at the correct level, then save. Kev MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Wed Aug 05 2020 11:27am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8976 |
Bear in mind that the figures stored in the car's suspension module are not actual height figures. They're just figures so that the system can see movement and which way it's going. You'll often see widely different values even though the corners are all at the same level. 2012 SDV6 - it's missing a couple of cylinders
Wed Aug 05 2020 4:27pm |
