Home > Technical > Range Rover Sport L494 Error codes Help |
StephenO Member Since: 06 Mar 2019 Location: Glasgow Posts: 30 |
I currently also have C1119 but not the others. Mines is related to a hydraulic pressure sensor which affects vehicle stability. I’m currently waiting on my warranty company to authorise works 2016 RRS Autobiography |
Mon Aug 03 2020 9:18pm |
41664166@online.no Member Since: 01 May 2015 Location: Moss Posts: 128 |
Then the red light goes out when refilling with fluid, but it flows out under the car at the driver's door, so a larger leak is enough
Tue Aug 04 2020 2:24pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
It sounds like you have already identified you have a leak and you just need to have a look underneath.
Tue Aug 04 2020 4:58pm |
Yeh definitely sounds like a leak which should be a bit similar to find. Mines is more of a sensor issue and the dispersal of the fluid, when I topped mine up it chucked it back out of the reservoir 2016 RRS Autobiography |
Tue Aug 04 2020 5:24pm |
Then I removed the plastic cover under the car on the driver's side. Found some gravel and mud there, so the pipes had rusted, and therefore holes in one. They were not pretty, so I wonder if I should change them all when I first do this. But found that they were not cheap, someone who has someone who can deliver at a nice price. Thanks in advance |
Tue Aug 04 2020 6:08pm |
