![]() | Home > Maintenance & Modifications > L320 Coolant Tank change...Faulty sensor/float |
Shaun W Member Since: 03 Mar 2020 Location: Dewsbury Posts: 79 ![]() ![]() ![]() |
Need to do mine, but struggling to find a replacement tanks, could anyone tell me the part number please? 2010 HSE TdV8 in Stornoway Grey.
Alexdc12 Member Since: 18 Dec 2021 Location: Essex Posts: 9 ![]() ![]() ![]() |
I used this
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
Did mine recently for the same reason old fluid bottle never lost a drop but fed up with the warning message, new ebay bottle fitted now I seem to lose coolant
So do I, I think.
Phil2k Member Since: 18 Jun 2020 Location: Anglesey Posts: 75 ![]() ![]() ![]() |
I need to do mine, it never really bothered me apart from the light cause I knew it didn't loose any fluid, until I had the inlet manifold replaced. Checked the water the other day and the tank was almost bone dry. Bought a dye kit from ebay and found this. Does anyone know if its a gasket or O ring before I undo the pipe
I too have been loosing coolant since having manifold replaced, found that the top coolant hose was leaking water, just removed , dried and cleaned and refitted and think it may finally be ok. |
That looks higher up judging by the pipe having dye on it. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory Born and raised in So Cal. Moved to the UK in 2018 for a few years. Now in Poland and looking at moving back to the UK. |
It wasn't dye on the fuel rail, just a scratch on the sticker that showed up under the uv light |
brimfull45 Member Since: 06 Jun 2022 Location: wrexham Posts: 25 ![]() ![]() ![]() |
Did you mange to sort out your leak? I have a leak in the same place? |
Hi, Did you mange to fix the leak? I have a coolant leak in the same area. |
