Home > Maintenance & Modifications > advice blue smoke help please/////////
adam01
Ireland 2007 Range Rover Sport TDV8 HSE Java Black
hi all
i,m wondering on start up i get a little blue smoke ! but only comes out the left side exhaust pipe....
... not the right side ? it only happens for a minute or so ! ..
oh yea when the blue smoke appears it slightly runs sluggish this all happens only a minute or so ??
thanks all
2007 RRS 3.6TDV8
Post #602508 Thu Jul 30 2020 3:05pm
Peterh
Blue smoke means your burning oil.Poss leakey valve seals on that side of the engine.
Post #602517 Thu Jul 30 2020 4:55pm
More likely the turbo oil seal is thinking about taking a holiday... Big Cry 2012 SDV6 - it's missing a couple of cylinders
Post #602521 Thu Jul 30 2020 5:53pm
adam01
which is it ?
is it going to be expensive
Post #602549 Fri Jul 31 2020 12:52pm
knwatkins
Whichever it is, are you going to do it yourself?
If not, take it to your trusted independent garage and I'm sure they will be able to provide you with a more accurate diagnosis and a quote. Kev
Post #602550 Fri Jul 31 2020 12:58pm
adam01
yes will be doing the work my self
thanks bud
Post #602551 Fri Jul 31 2020 1:14pm
knwatkins
I would suggest having a look at the amount of oil present in your intercooler. Kev
Post #602552 Fri Jul 31 2020 1:17pm
adam01
i think it could well be the stem seals , as it only happens on the rear left side and only when cold , even if i ref it when cold a little blue smoke comes out that left pipe not the right side ! .....
.....and when engine completely warmed up its clear in both pipes even if i ref it heavy
intercooler pipe all clean
Post #602564 Fri Jul 31 2020 3:49pm
adam01
well anyone ?
edit
well i,ve just started the rrs this morning and no smoke what so ever not even a tini bit,...
...clean as a whistle !!!!!!
i,m thinking a lazy glow plug ? as when it did smoke blue she ran rough for a few ....
... seconds ie: start up no blue smoke and all of a sudden she ran rough and then blue smoke...
... and then runs smooth and then no blue smoke clean then on wards
----When starting up a diesel engine, we need to use a glow plug to cause ignition of diesel fuel. Once the engine is warmed up, the use of the glow plug is not necessary as the heat of the engine makes ignition of diesel fuel.
If a diesel engine has a bad glow plug, it will create blue smoke at startup until it has warmed up
Post #602606 Sat Aug 01 2020 10:19am
