Home > Tips & Tricks > Intercooler Hoses
1richard1
Intercooler Hoses
Hi i've just ordered the set of 3 hoses from advanced factors, hoping this will sort out the lack of power below 2000 rpm.
I can find a how to replace the long which goes from the top down where you have to remove the cover in the wheel arch, does anyone have an exploded diagram where the 2 other are or a how for the other two, thanks in advance.
Post #602472 Thu Jul 30 2020 7:38am
The workshop manual is available here: http://www.mediafire.com/file/yunzrqm47py4...6.pdf/file
That should give you all the info you need. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #602478 Thu Jul 30 2020 8:40am
Eaters
If we are talking about the same things, my Indy found a split in one of the two top intercooler hoses on my TDV8 2008 and it was a 5 minute job. They are the two big ones on top of the engine. I think he just unclipped the top engine cover and then its a couple of jubilee clips on each hose.
Ah - perhaps they are different on the V6...?
Sorry if I'm talking rubbish. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #602489 Thu Jul 30 2020 10:55am
1richard1
Cheers for the info the V8 is a different set up to the V6, thanks for the manual still trawling through it.
Post #602501 Thu Jul 30 2020 1:40pm
1richard1
Changed the long one no obvious splits but a bit oily around the bottom, i think i may have been loose as only a few drips of oil come out, tested for about half hour i now can accelerate now Very Happy , got a long run to london monday so will see if fully cured then.
Post #602595 Sat Aug 01 2020 7:52am
