Home > Maintenance & Modifications > Wanted; plastic sill covers |
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 |
Might be worth posting this in the "For Sale & Wanted" section ... 2010 TDV8 - current - my first RRS, loving it so far......
Tue Jul 28 2020 7:34pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
Ah yes, good point. No idea how to move it over, so will post it again. Cheers. |
Wed Jul 29 2020 11:47am |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
Bite the bullet,,, the brackets will certainly not be worth saving. Shear the heads off the bolts,,you might be lucky and get a couple out, drill and re-tap the holes 8mm, just done mine,,,,,, not a big job at all. 2010 RRS, TDV8
Wed Jul 29 2020 5:56pm |
Easy for you to say....... |
Wed Jul 29 2020 7:30pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1538 |
If you decide to go down the removal route, I've got a pair of uncut sills from my 2008 TDV8. Not sure if they fit yours or not.
Thu Jul 30 2020 7:44am |
you have a PM |
Thu Jul 30 2020 8:27am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4973 |
Same part number now 2005 through to 2013 so imagine the should fit without any problem.
Cheers Col |
Thu Jul 30 2020 9:08pm |
Thanks Col |
Fri Jul 31 2020 7:24am |
