Home > Technical > EPB Screaming Banshee
Pufftmw
This ONLY happens after I've been using the brakes more than normal driving - ie down long wiggly narrow hills, exuberant B-Road driving, short sections of dual/roundabout/dual/roundabout etc. Red flashing lights, warning and so on. Turn off/on and it works fine again.
Not wishing to lose my car for any period of time to a garage so wondering what's the likely cause/fix?
Post #602205 Sat Jul 25 2020 5:54pm
knwatkins
Have a look at bodsy's brake bible and adjust the EPB. Don't leave it too long or it'll be new module time ££££ (or module rebuild, but a PITA nevertheless). Kev
Post #602207 Sat Jul 25 2020 6:49pm
gogsy1956
I totally agree with Kev,,,, get it looked at as soon as or it will cost you dearly. Is there not an indie you can visit and just have the rear brakes cleaned and adjusted,, it's probably an hours work. I normally have mine done at every service as it once cost me £1200 when the rears siezed on,,, new disc's,EPB module, pads and shoes.. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #602209 Sat Jul 25 2020 7:41pm
Pufftmw
OK - I will have a go at adjustment according to Bodsy's Brake Bible and see how I get on. Bought a 32mm socket & just summoning up the courage... Seems to be relatively straightforward but I'm sure I can muck anything up!
Post #602230 Sun Jul 26 2020 12:58pm
knwatkins
What's the worst that can happen Wink
Make sure to have a tin of brake cleaner and give everything a good squirt down whilst you are there Thumbs Up Kev
Post #602231 Sun Jul 26 2020 1:06pm
Pufftmw
I don't have any of that and I can't really nip to Halfords to get some! Oh well...
Post #602232 Sun Jul 26 2020 1:16pm
Alternative is a bit of tape across the EPB switch to prevent it being used until someone who knows what they're doing can do it for it you. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #602234 Sun Jul 26 2020 1:26pm
Pufftmw
Problem to that is that I instinctively use it all the time Laughing
Followed the bible more or less. My ratchet things didn't seem to be in the same place and would probably be better saying move lug up/down but got the job done! Whether or not that will have any effect remains to be seen Laughing
The problem with looking under your car is that you see things you don't want to see, such as rear brake backing plate is rusted to pieces and breaking off in bits. That and the ominous looking oil weeping that seems to emanate from the off-side rear diff someplace near where the drive shaft comes out.
That and more swollen nuts Big Cry
Post #602246 Sun Jul 26 2020 4:37pm
Pufftmw
Oh and putting the last wheel back on and there's a quiet but gentle hiss of a slow puncture FML
Post #602250 Sun Jul 26 2020 5:17pm
knwatkins
Well done for sorting it out Thumbs Up
Look on the bright side - you've identified those bits to sort out now, instead of it being picked up at a critical time, for example during the MOT. Steve, DevonZ did his rear seals on the diff today. It is a DIY job. Check his thread out here and just ignore my erroneous post Laughing Kev
Post #602256 Sun Jul 26 2020 6:16pm
Pufftmw
Doesn't tell me how unfortunately. Is probably something for my specialist and besides, to get into my garage at the moment, I have less than an inch either side, so a bit of a job. Confused
(Why is this upside down?)
Post #602257 Sun Jul 26 2020 6:19pm
Pufftmw
Just as an update, the fiddling around I did last weekend appears to have worked! Quite a few drives down twisty roads with heavy trailers to heat the brakes up and all quiet as a mouse Cool
Post #602600 Sat Aug 01 2020 8:40am
knwatkins
Awesome, well done Thumbs Up Kev
Post #602602 Sat Aug 01 2020 8:45am
aaronjb
Got the camera set to Australian? Mr. Green
Good job on the brakes! I am sure my EPB has got louder since I've owned the car .. but maybe that's just paranoia! It's not as loud as the one I test drove though, which shat itself as I parked back on the forecourt Laughing "Oh, it just needs resetting!" said the very optimistic dealer.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #602611 Sat Aug 01 2020 1:52pm
