Home > Faults & Fixes > Suspension fault C1A74-1C |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
The loom runs down through the front left wheel bay behind/around the wheel arch liner, if I remember correctly, and there is history of issues in this area. Be worth having a look there to check for any wiring damage. 2012 SDV6 - it's missing a couple of cylinders
Fri Jul 10 2020 8:43am |
Rossk3107 Member Since: 22 Sep 2013 Location: Glasgow Posts: 32 |
That will def be my next port of call π. I pulled and wiggles on all the wires at the connector and nothing...then I pulled on the wires heading towards the loom and the signal voltage dropped and raised so I thought for sure if I removed the shelve I would find a damaged signal wire ( I am sure itβs the orange red stripe) but when I did I found a slightly damaged supply voltage wire ( orange yellow stripe) now I am well and truest confused as the supply voltage was perfect π Present : 2007 RRS 3.6 TDV8
Fri Jul 10 2020 9:25am |
