Home > General > Changing Air Compressor on a 2010 RRS
idi
I have the "C1A13-64 Pressure doe not decrease when venting gallery" error and have been told the air compressor needs changing. I was quoted around £800 for the job from a Land Rover specialist which I dont fancy paying as it works fine most of the time and I only get the error occasionally.
I've had a look on ebay and they are roughly £150. My local garge says he has changed a few in the past so I was thinking of just taking it to him.
Few questions. Does the 2010 have a AMK or Hitachi compressor?
Also does the the part have to be "coded in" or is it a simple switch with the new one?
Any other complications that could happen?
Post #601406 Tue Jul 07 2020 9:54pm
For £150.00 that will be a crap Chinese copy that won't last as long as it took to fit it. Pay the extra and buy a decent one.
Post #601407 Tue Jul 07 2020 9:58pm
knwatkins
Have a look under your car to check. My 2010 had a Hitachi and I replaced it with a Dunlop compressor as it's a straight swap.
Made in the UK and you can buy the part for £195 + VAT here: https://www.lrparts.net/lr023964-air-suspe...relay.html
30 mins to fit if everything goes well.
Don't buy a cheap unit from eBay, you will have no end of problems. Kev
Post #601408 Tue Jul 07 2020 10:00pm
idi
Thanks for the link.
How do I know which of the two compressor's it is just by looking at it from under the car?
Post #601409 Tue Jul 07 2020 10:07pm
knwatkins
Also, before going out and buying a new compressor, you may want to consider checking and servicing the exhaust valve on your compressor first Thumbs Up
You'll need to remove the plastic cover. Here's a picture of my old Hitachi, which should help you in identifying yours...
 Kev
Post #601410 Tue Jul 07 2020 10:08pm
Strange really according to L/R Vin. AA000001 - BA708254 Hitachi fitted, BA708255 - CA725628 AMK fitted,
CA725269 - DA768669 reverted to Hitachi, then Vin. DA768700 on back to fitting AMK's. My car is in the range CA725269 - DA768669 and a MY13 and has the Hitachi fitted. Of course the above would not necessarily apply if the compressor has been changed previously.
AMK looks like this underneath.
Post #601411 Tue Jul 07 2020 10:47pm
mgrover
mine was upgraded from Hitachi to AMK even though it was a 2006 car so defo shoulda been Hitachi.
Post #601416 Wed Jul 08 2020 7:51am
knwatkins
I believe LR intially changed from Hitachi to AMK because there was a sourcing issue as a direct result of the Fukushima Daiichi disaster in Japan in 2011.
However, I'm not sure why they flip-flopped at a later date. I can only assume it must have been stock issues again. Kev
Post #601426 Wed Jul 08 2020 10:45am
idi
Had a look today. It's a Hitachi one.
Knwatkins, the link you sent says it is only 06-09 RRS. I'm guessing it will fit on a 2010 if it worked for you though so I'll go with that one.
Post #601428 Wed Jul 08 2020 11:55am
knwatkins
Yes, they are the same part. Kev
Post #601430 Wed Jul 08 2020 12:08pm
idi
Fitted today and goes up and down without errors now Smile
However I have noticed it is a lot slower to raise the car now. It takes around 15-20 seconds between each stage. I saw the "Vehicle raising in progress" message after about 10 seconds which it has never done before
Post #601478 Thu Jul 09 2020 4:17pm
knwatkins
Well done for fitting and saving yourself a fortune. That does sound like a long time. Remember it may do this if you have raised the vehicle a few times over a short period. You need to give the compressor a bit of time to refill the air reservoir. Kev
Post #601511 Fri Jul 10 2020 3:37am
idi
You seem to have all the answers. That was the case as I pressed it a few times in a short period when testing. After leaving it for a few hours it works instantly now. I just need to adjust by brain to not expect to hear the error message "ding" when lowering the suspension.
Thanks for your help.
Post #601533 Fri Jul 10 2020 11:19am
knwatkins
Great news Thumbs Up
Glad to have been of help. Kev
Post #601539 Fri Jul 10 2020 2:15pm
