Home > Maintenance & Modifications > Rear Door Speaker Grille
PeteF74
United Kingdom 2011 Range Rover Sport SDV6 HSE Lux Orkney Grey
Does anyone know if its possible to remove the speaker grille from the o/s/r door without having to take the whole door card off?? I don't want to prize anything off in case its not meant to be. Thanks.
Post #601232 Fri Jul 03 2020 4:07pm
Brit Plumber
You haven’t said the year but a 10 to 13 deffo can’t be. It is plastic riveted and hot melted in a number of places. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #601432 Wed Jul 08 2020 2:38pm
PeteF74
ah ok thanks for that. There is a slight crack in my speaker cover which isn't the end of the world but its a bit annoying on an otherwise spotless interior. A new door pad seems a bit extreme!
Post #601784 Wed Jul 15 2020 8:33pm
PeteF74
Its a 2011 by the way, so what you said applies to my car.
Post #601785 Wed Jul 15 2020 8:34pm
Brit Plumber
So when I said you can’t replace it, what I meant was, you can’t get a new replacement part. My rear right was cracked with a piece missing. I bought a replacement damaged door card with the correct colour grill which had no damage. I drilled off the plastic rivet heads and removed the grills. The tail is still in the post after drilling the heads off so I just pulled them out leaving a hollow post. I then bought some self tapping screws that were just bigger than the hole in the posts and appropriate washers. I had to grind some a bit shorter so they wouldn’t come through the front but it wasn’t a problem. You can’t tell and it looks good even on the inside. 2019 5.0 SC SVA (Current)
Post #601787 Wed Jul 15 2020 9:04pm
PeteF74
Thanks for that. Sounds like I need to find a salvaged card and strip that. I need a few parts now to get the car up to standard but on the whole its pretty good. I am just being very fussy.
Fixing the split on the side of the drivers seat base will be the next job!
Post #601850 Thu Jul 16 2020 4:18pm
