![]() | Home > General (L494) > Refurbish deployable steps |
thomas brown Member Since: 29 Mar 2016 Location: Norwich Posts: 559 ![]() ![]() ![]() |
Hi Barclay.
Barclay Member Since: 11 Sep 2018 Location: Aberdeen Posts: 4 ![]() ![]() |
Hi folks,
Martyn Member Since: 28 Jun 2019 Location: Suffolk Posts: 64 ![]() ![]() ![]() |
I decided to do mine myself they are very easy to remove all old paint was removed at the paint shop steps were masked up and sprayed now looking like new again as were looking really scruffy and mine is out of warranty....
Concept Member Since: 15 Sep 2013 Location: Milton Keynes Posts: 68 ![]() |
Aside from the side steps having a mind of their own...but that's ok says the dealer, they are saying the wear on the side steps is acceptable.
Thespecialone Member Since: 29 Jun 2020 Location: South Yorkshire Posts: 5 ![]() ![]() |
Hi All,
Hi, I have a brand new OEM left hand side step for sale still in the box with fixing kit.....£250 |
Thanks Martyn, unfortunately it’s the right one that needs refurbishment on mine.
There's only 4 grub screw holding the steps on mate it can be removed in 5 minutes |
Yeah, i removed those 4 hex grub screws but the tread plate was solid, wouldn't budge |
Give it a tap with a rubber mallet |
Thanks Martyn - I managed to get them off with some persuasion from a rubber mallet. 🙂 |
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 169 ![]() ![]() ![]() |
Hi Martyn what paint did you use to refurb your side steps? How did you strip the old off? Have they lasted ok? Cheers, Pete. L494 3.0L SDV6 Autobiography in Chile Red (Current) L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss) |
RRSporter Member Since: 08 Nov 2012 Location: UK Posts: 61 ![]() |
Hi Pete Resurrecting and old thread here. I had drivers side repainted at body shop in anti slip truck bed type paint. I’m afraid 18 months later lots has worn off. I’m a little unsure how to proceed. My may did use some alloy etcher first as well to try to make the coating adhere. Has anybody found a long lasting way or refurbishing them? Powder coating perhaps 🤷♂️? 3.0 SDV6 HSE L494 |
