![]() | Home > Technical > Fault codes U0421-68 & C1B00-64 after front bushing repa |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9029 ![]() ![]() ![]() |
If HDC and DSC aren't working, that points to a wheel speed sensor or related wiring problem 2012 SDV6 - it's missing a couple of cylinders
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
Have you had a 4 wheel alignment carried out? I understand that if you have work done on the wishbone, it needs an alignment check/adjustment and if not done can throw up faults. You really need someone who knows these cars, preferably with a Hunter rig. |
mycar Member Since: 15 Jul 2015 Location: Antwerp Posts: 17 ![]() ![]() ![]() |
I did read the alignment statement after posting my question. It makes sense although I marked the positions of the alignment bolts and used these marks for alignment when installing the wishbones with replaced bushings.
Wheels aligned at a dealership and it seems to resolve the issue. (Only 40 miles done so far) Since the repair the warning messages did occure less and less. Where initially these would appear with 1-2 miles, after 2 weeks I could do between 10-15 miles before these would pop-up. Hopefully this information helps others. |
