Home > Maintenance & Modifications > Parasitic battery drain. |
Mantaraman Member Since: 04 Jul 2018 Location: St Albans Posts: 16 |
Can anyone give me some ideas on what might be the cause, or how to trace a battery draining fault, RR Sport V8 Diesel, 2007. Drain is, I think, about 6mA.
Fri Jun 26 2020 4:43pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
As Andy says, 13V is too low,, a constant 13V would not fully charge a 12V battery. I see 14.65 on mine,, it will vary but mostly it is the higher value.
Fri Jun 26 2020 6:01pm |
Is it a calcium battery and is it a YUASA by chance? 2019 5.0 SC SVA (Current)
Fri Jun 26 2020 7:28pm |
Thanks for the replies, I bow to your superior knowledge. I might have mis-read the ammeter when looking at the rate of drain, similarly, I might be mistaken on the charging voltage. However, what I do know is if I re-charge the (Exide) battery and disconnect it, for any period of time, there is no loss. If I leave it connected, after just a few days, the battery is flat. I must therefore assume that something on the car is pulling a current - but I don't know what and where to start looking. I shall repeat the test lamp/pulling fuses exercise in case I missed somehting first time I did it. I used the car this morning and almost everything works correctly - the drivers door window wouldn't, initially close up the the top, it would re-bound down as if the safety function had kicked in. Has anyone had similar window problems? |
Sat Jun 27 2020 11:22am |
The problem with some new batteries and what I’ve had with YUASA silvers (calcium), one they’ve gone flat, they are shot. They only ever get a surface charge. My CTEK would show green and fully charged but as soon as I tried to start the car, the charger would drop back to 3. It could we worth just getting that battery checked for peace of mind because if it’s a calcium battery, it will be knackered even at 4 months old. 2019 5.0 SC SVA (Current)
Sat Jun 27 2020 11:50am |
I originally thought the battery must be faulty. I bought it on eBay and contacted the supplier and returned it for checking. They've confirmed there is no fault - so the fault must be on the car - and this is confirmed as I get the same symptoms on another battery borrowed from another vehicle.
Sat Jun 27 2020 12:07pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
see here for more info and a link
Sat Jun 27 2020 12:56pm |
What’s your timeline,
Sat Jun 27 2020 2:36pm |
Regarding your window problem,,, Keep dabbing on the switch until you get the window right too the top,, then hold the switch in the up position for 3 secs and release,,, your window should work correctly after that.
Sat Jun 27 2020 2:43pm |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 |
Have you checked your upper tailgate switch, this was the cause of my battery drain and many others on here.Have a look at my posts regarding battery drain |
Sat Jun 27 2020 6:20pm |
ondafly Member Since: 03 Mar 2017 Location: Ireland Posts: 50 |
my rear window defroster caused my battery to run flat. Disconnected it, and all good. Wiring had gone bad on it. |
Mon Jun 29 2020 8:21am |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 899 |
Worth trying above suggestions, but it could be anyplace. It took an Auto electrician 3 days to find the parasitic drain on my car.
Mon Jun 29 2020 10:13am |
Thank you all for your comments, I've now learnt a lot more about the problem. With the engine running, the charge from the alternator is over 14.5V, the battery stays OK if I use the car - no fault here. The tailgate glass switch has collapsed - I've fixed this. The windows work OK at the moment - as does everything else.
Mon Jun 29 2020 9:33pm |
Have you also pulled the relays? Maybe it’s a bad relay cycling? You could try pulling one at a time. 2019 5.0 SC SVA (Current)
Mon Jun 29 2020 10:06pm |
