![]() | Home > Faults & Fixes > Botched repair? |
Keith1961 Member Since: 09 Mar 2020 Location: Belfast Posts: 23 ![]() ![]() ![]() |
Got a puncture in the off side front wheel and discovered leaking pipes with compression joints and a pipe with no connection!
New to this....older generation |
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 191 ![]() |
ah,,the ace pipes,compression joints not really an issue,quite common i think,but not so sure about the open one.Looks like it might be the reservoir feed.Is the ace reservoir full of oil ?.
What is ace? |
It's your hydraulic anti roll bars.
Active Cornering Enhancement. Its used to control the anti roll bar system hydraulically on your vehicle 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18” Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning 😎 |
Ugly!!
Are your engine under trays missing? I can see you have some plastic trim missing but in some of the photos I can see ground where I’d expect not to. 2019 5.0 SC SVA (Current)
The level is low as you predicted so I will top up today, I tightened the weeping compression joints when I had the wheel off.
I have never had a RRS before, certainly seems like there are parts missing, like the undertrays you mention.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
Definite bodge job. They've used a tie wrap to hold the pipe up. 2012 SDV6 - it's missing a couple of cylinders
I would say new pipes at £250 plus flush and filter at the minimum and the missing shields. I appreciate they will says it’s an older car but I think those pipes will just get you by and they’ll fail again when your garage warranty runs out. 2019 5.0 SC SVA (Current)
Thanks guys, I will get a price for proper repair from BLRC and challenge the dealer, I only had a three month warranty, but if the repair is deemed unsafe and likely to fail I may have a case. |
