![]() | Home > General > Where to buy tow electrics for late 2012 sport. |
The part number for the L/R kit for a MY12 on is VPLST0071 for the 13pin plug and VPLST0070 for the N&S 7pin plug. You should be able to cross reference to a pattern part I would think. I did manage to pick up a new genuine L/R 13 pin kit off ebay for £60.00 but that was just luck I think. A member on here 215m3 just recently bought the wrong one for his car, he might have what you need unless he managed to return it. Have a look at the link below, I have added a pdf file of the fitting instruction for 0071 kit to my gallery if you wanted a quick look, should be able to download from there as well if you wished to I think.
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
I bought from here and they were spot on for a 2012 SDV6 pre-new shape
RJM16 Member Since: 11 Nov 2016 Location: Worcestershire Posts: 29 ![]() ![]() ![]() |
Agree with PF Jones as the system is plug and go! |
You’ll probably need or at least want to have the files updated. That will stop the parking sensors beeping when the trailers on and you’re in reverse and I think it also alters the suspension. 2019 5.0 SC SVA (Current)
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 ![]() ![]() |
Do you need to go back to Land Rover for the software update to tell it you have a tow bar ? 2017 SVR. SVO Scafell grey Ebony interior
If you have the IID tool you can do it yourself or any good indi. could do it for you.
215m3 Member Since: 13 Sep 2018 Location: Cambridge Posts: 48 ![]() ![]() ![]() |
Yes a nightmare. I managed to send the part back as was from Rimmer Bros. I purchased a part from LR from ebay at a discount/cost. Yet to fit it, but I know what to do as had it apart 3 times now. I got mine from Beadles Sidcup LR, maybe give them a call as they checked against my vin before sending. The plugs look correct and there is also a wire for the soft close boot I was concerned about. Goodluck with it 2010 3.0 TDV6 RRS Overfinch GTS 1987 BMW E30 M3 2.4 Turbo 1990 BMW E34 M5 3.6 Trackcar |
Ordered my dedicated loom tow electric's from PF Jones this morning on the phone as it was quit confusing as to which was the correct loom when looking on website.
It shouldn’t be confusing.
Electric's all fitted once I had the bumper apron off as couldn't get my hand up between the chassis and the bumper to reach plugs. Only took about a hour and a half in the dark working with a torch.
G REG Member Since: 11 Apr 2020 Location: Kent Posts: 2 ![]() ![]() ![]() |
RRS 2005
sportgoogle Member Since: 13 Jun 2020 Location: Monmouthshire Posts: 16 ![]() ![]() |
Bearmach.com
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 ![]() ![]() |
it should "work" without but will not silence parking sensors or turn off the fog lights 2012 SDV6 HSE (technically its hers) 2000 D2 TD5 - definitely mine 2005 D3 V8 Metalian Camper trailer for adventures |
