Home > General (L494) > Fuel cap not twisting tight
DZ
Hello all,
Firstly an introduction - my name is Dan and I've just picked up a late 2016 RRS AB at the weekend. It's got the 2017 updated interior/screen and was an ex-LR demonstrator so has been fully specced. I'm absolutely over the moon with it Smile
Quick question: I went to put some diesel in and found the yellow round fuel cap (not the exterior door flap) to be loose. I did not have to twist it counter clockwise to unlock it nor can I twist it clock wise to lock it into place. I've done a search on here and on the wider interweb but this just seems to bring up issues with the exterior door flap not locking (or the opposite).
Am I right in assuming that (a) the cap should twist tight to maintain a good seal and (b) this filler cap is therefore ready for replacement?
The current situation does not seem to trigger any fault codes or impair the car's performance in any way.
Thanks for your feedback - I am looking forward to spending more money on the car Wink
Regards,
Dan MY17 RRS Autobiography - Corris Grey
Post #599967 Tue Jun 09 2020 5:54pm
Sudds
Hi Dan
Welcome to the forum. Regarding the fuel cap I have just tried mine and to remove it, it turns anti clockwise half a turn with no resistance and then stops, it then turns another quarter of a turn anticlockwise and then comes off. To put it back on it turns clockwise three quarters of a turn and then stops, if you try to turn it any further it just clicks but doesn't tighten anymore. This has been the same on all my previous LR cars.
Hope this helps
Dave...
Post #599995 Wed Jun 10 2020 8:23am
DZ
Hi Dave,
Many thanks for the welcome and the feedback - I appreciate it.
I've just checked again and the cap is definitely just twirling around freely without catching at all. I've tried pushing it down slightly without any success so I'm picking up a new one from my local LR dealer (£19 so not too bad). Speaking to the parts chap he reckons the spring mechanism inside the cap has failed ...
Cheers!
Post #599999 Wed Jun 10 2020 12:21pm
DZ
Update: problem solved
Update: The problem has been resolved Smile Got my new fuel cap from LR and this one locks properly! In the end the problem wasn't the spring mechanism but broken "teeth" on the ring.
Cheers!
Post #600093 Thu Jun 11 2020 6:00pm
Sudds
Glad you are sorted Thumbs Up
Post #600119 Fri Jun 12 2020 8:35am
