Home > In Car Electronics > Harman Kardon Logic7 sounds 'tinny'?
abiopete
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Am i imagining it or is there something wrong with mine? It sounds like all the sound is coming out of the front speaker in mono or something.
The door speakers are working, i can feel them vibrate if i put my hand on them.
Turning the bass right up helps but turning the sub up just makes the back end shake.
The front/back option (dont know what its called) is at factory default in the middle/front.
It just sounds tinny. The wife's Peugeot 3008 sounds better/normal and the Insignia i had prior to this does too. L494 3.0L SDV6 Autobiography in Chile Red (Current)
L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss)
Post #599740 Fri Jun 05 2020 3:35pm
ilard
I had this system. It is not a great sound system. But it is not a bad system, and far from it. If you’re able to turn the bass right up then something is horribly wrong! I may have had bass turned up 1 notch but that’s it.
Has the subwoofer gone? It feels like one speaker might have gone kaput, perhaps due to a wiring issue. You might need to take the whole thing apart. But first you need someone with ears to compare with what they know. I suggest, social distancing permitting (ha) to test drive another Sport with Logic7 and compare the sound of the tunes. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #599800 Sat Jun 06 2020 9:49pm
Buckster
Speak to these guys for upgrades, even simple stuff like sound deadening makes a huge difference to a logic 7 Thumbs Up
Although the car shown is a later Sport they have had many dealings with L320 shape
https://www.audiofile-incar.co.uk/audio-up...13-onwards 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #599817 Sun Jun 07 2020 10:30am
Brit Plumber
Have you got Logic 7 turned on? There’s an on off button in the menu. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #599905 Tue Jun 09 2020 8:17am
abiopete
I'll have a proper look around and make sure all the speakers are working, didn't realise one speaker could make such a bad difference to the entire system. L494 3.0L SDV6 Autobiography in Chile Red (Current)
Post #599906 Tue Jun 09 2020 8:50am
abiopete
Yes, i've switched between Logic7 and Stereo. To be honest i was hoping normal stereo would sound better but its the same. L494 3.0L SDV6 Autobiography in Chile Red (Current)
Post #599907 Tue Jun 09 2020 8:53am
abiopete
I'd really like to get the system working properly than treating the symptoms. Thanks anyway pal. L494 3.0L SDV6 Autobiography in Chile Red (Current)
Post #599908 Tue Jun 09 2020 8:55am
Brit Plumber
You have something wrong then as there’s a big difference between the two. 2019 5.0 SC SVA (Current)
Post #599912 Tue Jun 09 2020 9:55am
Brit Plumber
What spec is it as it’s possible to turn the logic 7 buttons on in the CCF but not have the hardware. 2019 5.0 SC SVA (Current)
Post #599913 Tue Jun 09 2020 9:56am
abiopete
Its the Autobiography, all the speakers are physically there and they have the Logic7 logo on them.
No idea what a CCF is though Laughing L494 3.0L SDV6 Autobiography in Chile Red (Current)
Post #599914 Tue Jun 09 2020 10:05am
Brit Plumber
Don’t take this the wrong way but is it defo an Autobiography? Lots of dealers sell the HSE as a AB. Does it say AB on the V5?
The reason I ask is that you say it’s a 2013 AB TDV6 in Baltic Blue. According to the literature I have, the TDV6 ended in 2011 and was replaced by the SDV6 and Baltic Blue was suspended in May 2011 (But was back for 2012 which could be down to the Japanese shortage of pigment).
I’m not questioning your vehicle, more that a dealer hasn’t done a fast one. 2019 5.0 SC SVA (Current)
Post #599918 Tue Jun 09 2020 10:29am
Are you sure it is a genuine factory A/B ?
Post #599919 Tue Jun 09 2020 10:30am
abiopete
Well bu99er me its an SDV6, whats the difference?
Info attached, looks legit.
Thanks for your help gents Thumbs Up
Post #599921 Tue Jun 09 2020 10:43am
Brit Plumber
Difference is .3 sec to 60 and 4mph top speed. Realistically it’s a better engine with more power but more importantly it’s coupled with an 8 speed box. 2019 5.0 SC SVA (Current)
Post #599922 Tue Jun 09 2020 10:49am
Looks like it is according to that, but as Chris said there is quite a difference between having logic 7 switched on or off.
Post #599923 Tue Jun 09 2020 10:52am
