![]() | Home > Technical > AC condenser |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5032 ![]() ![]() ![]() |
Yes |
2010 3.6L TDV8 Air Conditioning Malaysia Boleh!
Looking at the images I have found none seem to match exactly what I have,,,, are the front 2 rads part of the AC system?. To me it looks like the front 2 are AC, the next one is the intercooler and the one right at the back is engine coolant. Condensers I have seen for sale only indicate one Rad, No mention of the small one at the very front.
is your profile correct? or is your car supercharged ? |
Supercharged 3.6 TDV8 |
my guess would be the middle one.
I can see the pipes coming from centre one that go to the high / low pressure service valves,, which matches the line drawing from advance factors site,, just never seen mention of this tiny one at the front,,, might ask my indie.
It's a fuel cooler 2010 RRS, TDV8
No obvious damage.
I changed my disco and sport ones they do suffer damage through the hole below the number plate.But you don't always see it but it is common |
Yeah,, i've had a look about as best as I can but as you know most of it is buried out of sight,, I can see a slightly damp section on the bottom left of the condenser,, possibly oily residue from the refrigerant but no sign of any damage 2010 RRS, TDV8
Well If you see oil. Change it. |
