![]() | Home > Maintenance & Modifications > Front Seat Remover - 2006 Sport? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
You can remove the seat base cushion by removing four torx screws underneath. Easy to access and then just lift the cushion out. It leaves the loom etc exposed. Make sure you disconnect the heating wire and the occupancy sensor wire. 2012 SDV6 - it's missing a couple of cylinders
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 332 ![]() ![]() ![]() |
Thanks for yours!!! Am I going to have any problems with Air Bags going off all over the place? Andrew Kennedy |
Little more details if poss please......where should I look for the four holding bolts? Andrew Kennedy |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
Yellow and orange connectors Are airbags |
Hi Andy......Haven't taken the car out for a decent test, but changing the sensors seems to have sorted the problem. Regarding "taking the front seat out" to look at the wiring (without having to take the complete chair out). Would it be advisable to disconnect the battery? Air Bag problems? And do you know where those 4 bolts are to release the seat - perhaps it will be obvious where they are when I take a look??? Always glad to receive your advice!!! Andrew Andrew Kennedy |
If you are removing just the base. Leave batt connected.
https://www.rrsport.co.uk/forum/topic43630...at+removal
Thanks for yours!! Would I be correct that in the article you suggest I looked at, is JUST REMOVING THE SEAT and not the complete complete CHAIR? Andrew Kennedy |
Does your navigation work ok ? |
Andrew Kennedy |
A lot easier just removing the seat Base if all you need is access to the wiring underneath. 2010 RRS, TDV8
Navigation working okay. But with no voice commands available.. I have taken the disk out a couple of times, waited for a few minutes, replaced the disk with the hope it might sort things out.....it didn't Andrew Kennedy |
Whoosh Member Since: 05 Nov 2021 Location: Scotland Posts: 35 ![]() ![]() |
I’ve just bought a 2008 sport after having had a L322 for a couple of years .
You can just remove the seat base alone. It comes out as a metal pan with the foam and leather cover all as a unit. There are four Torx bolts - two front-ish, two rear-ish. Undo and the seat base should lift out with a bit of a jiggle. Remember to unplug the occupancy sensor and the heating element connector before lifting the base too far.
