Home > In Car Electronics > Sat nav Bluetooth radio issues
Colin7524
United Kingdom 2005 Range Rover Sport TDV6 S Java Black
Hi I have 2005 sport Tdv6, these are my problems hope you can help
I have screen displaying no navigation available
Voice control not working
Sat nav doesn’t even start up or let me eject disc
Had new updated Bt module from Wiggsy so we can assume that’s ok
If I put by pass loop on the most system at the module I get sound on radio re plug it into module no sound
Sat nav originally worked then started flickering then went completely
Phone paired to start with but caller couldn’t hear me and had to enter code each time now doesn’t even pair (I phone 7s)
Have tried fuses relays as others have suggested and tracing wires for breaks etc to no avail
Sure there’s more but, hope you have some new ideas out there
Have also tried replacing sat player with other one same problems
Post #599718 Fri Jun 05 2020 10:15am
It sounds very much like the unit under the seat you say you changed.
I would do this: should eliminate nav problems
Works with D4 BT
https://www.rrsport.co.uk/forum/topic55655.html
What are you bypassing ? The display ?
Post #599728 Fri Jun 05 2020 12:45pm
Colin7524
No the Bluetooth module only way to get sound on radio
Post #599756 Fri Jun 05 2020 7:19pm
replace fuse 52 behind glovebox
or fuse 58 if the LCD isn't working
Post #599761 Sat Jun 06 2020 8:49am
Colin7524
Wish it was that simple been through all the relevant fuses and changed them no joy
Post #599763 Sat Jun 06 2020 11:28am
