Home > General > Rear tyre inside wear |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
That's odd. It must be way out. Please post your alignment results when you get your printout. It'll be interesting to see what the angles were on that corner. Kev
Wed Jun 03 2020 10:44pm |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
Thu Jun 04 2020 9:56am |
It appears they were scrubbing because of the excess negative toe you have. That would mean that the rear wheels are toeing out where the front of the wheel is pointing away from the centreline of the vehicle. In addition, the overall negative thrust angle would have been causing the rear axle to crab over the left. I would expect the tyres to be feathered on the outside of the tread pattern. You can detect this by running your fingers around the circumference of the tyre where you will be able to detect high spots on one side of the tread block compared to the other.
Thu Jun 04 2020 1:47pm |
Well I may swap the front and rear tyres over to extend their life anyway. |
Thu Jun 04 2020 4:32pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
No wonder it was eating the rear tyres. They were well out! 2012 SDV6 - it's missing a couple of cylinders
Thu Jun 04 2020 5:14pm |
And don’t swop sides if they’re directional tyres 2019 5.0 SC SVA (Current)
Thu Jun 04 2020 7:52pm |
Thu Jun 04 2020 9:49pm |
