Home > Faults & Fixes > 2006 Range Rover Sport HSE Several Faults!? Need Help! |
Goffy Member Since: 31 Oct 2018 Location: Milton Keynes Posts: 82 |
I've heard that multiple fault codes can be due to a failing battery, which stops the systems closing down properly when you switch off.
Sat May 30 2020 1:32pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
The error codes aren't complete, unfortunately. There will be two more digits for each one which help to point at specific items.
Sat May 30 2020 2:04pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Brake light bulbs all working? 2006 2.7 TDV6 HSE in Cairns Blue. |
Sat May 30 2020 4:32pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 948 |
As has been mentioned,, battery is a good starting point, get a proper test on it to see if it is on its way out. Make sure all lights are OK and no cheap bulbs have been fitted as this has also known to cause issues. Search the forum for topics on this and check all the cheap options first 2010 RRS, TDV8
Sat May 30 2020 6:05pm |
