Home > Faults & Fixes > 2010 Range Rover Sport 3.0 TDV6 - Gearbox fault
Gmighty
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Chawton White
Hi all and thanks in advance for taking a look at this topic, I recently bought a Range Rover Sport 3.0 tdv6 been happy with it as of the other day it knocked itself out of gear when approaching a roundabout i fiddled about with the gear stick and it went back in its like it was a loose cable or maybe something to do with the gear stick itself the gearbox isn't crunching or making any unusual knocks bangs and goes through the gears fine but TODAY the gearbox fault WARNING light came on does anyone know what this might be ? I turned it off and on and the warning light is not showing anymore
THANKS !!!
Post #599417 Sat May 30 2020 1:48pm
Disco_Mikey
Seized gear linkage
Very common, I even keep the parts on the shelf, they are that common Laughing
Post #599422 Sat May 30 2020 5:48pm
Oldandconfused
Emergency fix if you cant get in a garage is to get underneath, drop the gearbox shield clean the linkage with penetrating oil or similar while working the lever then spray some silicone grease on it.
I'm sure there is a how to change it guide on Disco3 forum, maybe even posted my DM.
Post #599424 Sat May 30 2020 6:20pm
