Home > In Car Electronics > Rear Sensor problem
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
Rear Sensor problem
2006 Sport. Here we go again about my rear sensor problem!!!! I've had the rear bumper off and all wiring and connections seem okay......Changed the Parking Sensor Module in the boot area.......and I'm still having the same problem with the rear sensors sometime working as they should 50/50 with staying on constantly - with a difference now - the red light on the dash stays on constantly when when they are not working properly. Does that indicate where the problem might be?!??!?? Andrew Kennedy
Post #599398 Fri May 29 2020 3:46pm
You need a tool to read the live sensor data when the fault is present.
Or just change out all rear sensors
Post #599400 Fri May 29 2020 4:10pm
andrew kennedy
Thanks for your Andy. All your input gratefully received!! Is it going to be cheaper to buy new sensors? Or buy the testing tool? I live in the wilds of Brittany and it would have to be an Amazon purchase I'm thinking......What would I put up on "Amazon Search" to find the tool??! Andrew Kennedy
Post #599404 Fri May 29 2020 5:39pm
Well the usual tool is gap iid £500. But they are useful for loads of things on your car.
So yeah sensors cheaper.
Post #599405 Fri May 29 2020 5:43pm
mgrover
My issue was the loom itself it was brittle and breaking. A used loom for 50quid sorted me out or a new loom for 80 can
Post #601916 Sat Jul 18 2020 8:19am
