Home > General > Air to coil coversion
Olav
Norway
I have tried to get air to coil conversion set to my Range rover sport TDV6 With ACE 2006 model but no one available for this car only the 4.4 gasoline. Anybody know if such coversion exist for this model ? Range rover sport TDV6 autobiography 2014
Discovery 5 HSE TDV6 2018
RANGE ROVER SPORT TDV6 2006 HSE dynamic pack and brembo brakes ,DVD. Zambezi silver.
DISCOVERY 4 3.0 HSE 2010 ,buckingham blue
Discovery 4 3.0 HSE luxury 2013 .
ROVER SD1 3500 vanden plas 1985
MASSEY FERGUSON 4235
Post #599356 Thu May 28 2020 2:05pm
Look up parts for discovery.
You may need to remove ace
Post #599369 Thu May 28 2020 10:11pm
garrycol
Australia
Why would you do this hack job - just buy a Toyota. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #599375 Fri May 29 2020 4:39am
Some people still think that air suspension is unreliable, I think, because of the early versions on the P38 etc.
Putting coils on an RRS will mean messing with the off road ability too unless you can get the off road ride height with correct camber settings etc. Camber changes with ride height and I wonder if the standard arms have sufficient camber adjustment to get the tyres sitting correctly if sat at off road height all the time. If you can't do that, then you're stuck at the standard on road height which is a bit limiting for ground clearance. 2012 SDV6 - it's missing a couple of cylinders
Post #599383 Fri May 29 2020 9:00am
