Home > General > Part number.
DeeWee
England 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Part number.
Hi would anyone please be able to help with a part number for a right rear ride height sensor. Apparently there are two different types and I don't want to order the wrong one. It's the one using pins 1,4 & 5 if that's any help. Thanks in advance.
Post #599332 Wed May 27 2020 11:44am
knwatkins
As yours is a 2010, the part number will be LR023650 if you have dynamic response. If you don't have dynamic response, you need part LR023648. Kev
Post #599342 Wed May 27 2020 9:52pm
DeeWee
Thank you very much I can now go ahead and order it. Is it straight forward replacement or does it need programming do you know? It has got the dynamic response. Thank you again for your help.
Post #599397 Fri May 29 2020 3:11pm
knwatkins
No problem.
It's easy enough to physically fit and you will likely need to perform a suspension calibration routine with an IID tool or similar. Kev
Post #599401 Fri May 29 2020 4:13pm
