Home > Faults & Fixes > 2006 range rover sport tdv6 not revving over 2.5k
reice
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
Quick run through its had a full engine rebuild about 2 months ago new turbo, EGR has been deleted, its had a new MAF, it was running fine till the injectors were removed and the seals were replaced because they was slightly leaking, since that it will not rev over 2.5 k engine system fault comes up no power when driving at all!!! and the all terrain is disabled i have checked all the ovbs connects to see if there lose but there all ok, i've even replaced the throttle pedal to no avail. i'm really scratching my head on this one Yawn any suggestions guys ?????
these are the codes that are coming up
Post #599186 Fri May 22 2020 5:37pm
Throttle pedal wiring ?
Maybe damaged it below the window screen when replacing injectors
Post #599187 Fri May 22 2020 6:16pm
reice
hi andy im going to check the wiring today where abouts exactly under the windscreen mate ?
Post #599201 Sat May 23 2020 12:36pm
