aaronjb
Drivers seat suddenly has limited range of forward/backward | |
I've had a search around and I've seen plenty of posts where the seat stops moving completely, or one range of movement stops working completely (usually fuses, switches etc) but this is different..
My drivers seat works fine in every direction except forward & backward, where it suddenly has a limited range of motion of about 1" or so, right at the back of the range.. it still moves on the switch, still tries to recall the memory position, but only gets part way forward and then "click" - which sounds like a range limit switch clicking (microswitch?) or a relay clicking off.. and that's it.
I've had a look under there and I can't see anything stuck in the rails or obviously wrong with the lead screws (probably not what they're called but anyone who has run a lathe or mill will know what I mean ). Did find an obnoxiously sharp cable tie, though
It's a problem because, as my Fiancee would say, I only have little legs
Any suggestions? I'm not even sure I can get the seat out as the rear bolts are probably trapped underneath it unless you move the seat right forward, no? 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Sun May 17 2020 10:27am |
