![]() | Home > Orders (L494) > Deployable sidesteps no longer a configurator option |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
They're available to specify in the accessories section of the configurator. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Netsters Member Since: 07 Nov 2011 Location: London Posts: 175 ![]() ![]() |
Can only see fixed steps as an option now, no deployable.. Range Rover Sport SVR - Santorini Black
In the Popular section? (NOT the Exterior section) L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
sbradleyrr Member Since: 13 Jul 2018 Location: Cheshire Posts: 13 ![]() ![]() |
It doesn't seem to be an option for the SVR but its is for any other spec. I wonder if this can still be fitted by the dealer after delivery? |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 915 ![]() ![]() |
They were always a dealer fit. Probably took too much time to be a factory fit
Jjvd21 Member Since: 20 Dec 2011 Location: Chicago Posts: 242 ![]() ![]() |
2020 MY comes pre-wired for deployable side steps in order to minimize the number of panels that need to be removed during fitting |
Mike London Member Since: 22 Jul 2014 Location: Cotswolds Posts: 55 ![]() |
Showing as an option under ‘Popular Accessories’ in configurator ... 2014 RRS AB Santorini Black |
DangerMouseUK Member Since: 16 Jul 2016 Location: London Posts: 528 ![]() ![]() ![]() |
I've seen this as well, no where to be seen on the SVR page and if you go to a non SVR model and look it specifically says Not for SVR. But they were fine on the MY20 model !!! So whats changed for MY20.5 lol. Anyone got any ideas? Non JLR Vehicle |
My idea is https://www.pegasus4x4.com/land-rover/rang...nge-rover/ just waiting for some feedback before I follow suit. 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
The LR ones do fit on the 20.5MY I've checked.
never ready Member Since: 05 Sep 2014 Location: Suffolk Posts: 34 ![]() ![]() |
Hi, did you get them fitted?
Parts department found a 20.5MY VIN and went off to check and said it was fine . . . Non JLR Vehicle |
R22Flyer Member Since: 04 Feb 2007 Location: South Posts: 109 ![]() ![]() ![]() |
its on the configuration under popular accessories, Tesla Model Y - 2023
The New Defender configurator is the same, quite a few accessories that are dealer fit and not added to the original build spec have either disappeared or moved to the accessories section. Some items that are listed as factory only aren’t - the Warn winch for example is a £5000 dealer fit accessory now but at least that price includes all parts needed to comply with the pedestrian safety rules which initially the configurator showed as a separate item, now if you click on the winch it also highlights the mounting kit and adds the total cost to your car’s cost. Only Thing the Defender configurator doesn’t show is if you add say the winch and black accessory wheels the image of the car doesn’t change to show them added, to show the black wheels you have to go right back to the wheels section in the initial builder sections and highlight a different style of wheel!
