Home > Faults & Fixes > New owner with 'restricted engine performance' query |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
Your gut feeling should be to have the fault codes read, and a fault diagnosis carried out before replacing parts unnecessarily |
Thu May 14 2020 3:57pm |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 |
I had this and it was the throttle sensor Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Thu May 14 2020 9:27pm |
Throttle body,I had same problem the flap in the body was stuck,LR assist came out pulled front pipe off freed the flap & all was good.luckily mine is still under warranty so when it went in for service they fitted a new throttle body. Andy.
Fri May 15 2020 5:57am |
Where that little yellow mark is put a screwdriver under the metal clip,lift up & pull the front pipe off & flap is there,you can spray in with throttle body cleaner to help it.
Fri May 15 2020 6:01am |
phey708 Member Since: 14 May 2020 Location: Lancashire Posts: 3 |
Thank you everyone. Unfortunately it didn't store any codes so I don't think replacing the MAF sensor would really work at this stage. I did notice that it was a new-ish part (looked to be in good condition) so it may have already been replaced recently anyway.
Fri May 15 2020 12:09pm |
