Home > Maintenance & Modifications > Air con
JohnBlueSport
United Kingdom 2007 Range Rover Sport TDV6 S Buckingham Blue
Air con
Hi, Got a problem with the sport. Recently aircon blowing slightly warm air when switched on, took it to the garage for regas, they said it was full and holding pressure, but still blowing lukewarm air, anyone had the same issue and how they resolved it or is it a case of just replacing everything in hope of fixing it, just cold air is needed in this weather
Post #598880 Wed May 13 2020 7:57pm
geoffsnook
Was it a specialist who tested the gas Thumbs Up
Post #598906 Thu May 14 2020 11:48am
JohnBlueSport
Had it checked by Kwikfit if that helps, checked last night, can here the revs drop when aircon is switched on
Post #598931 Thu May 14 2020 4:42pm
Disco_Mikey
Air con pressures need monitoring, to see if the compressor clutch in engaging and disengaging, and also for pressure increase and loss
Much more to an AC system than just a regas and hope for the best Wink
Post #598935 Thu May 14 2020 4:58pm
geoffsnook
You really need a specialist to tell you if it is full of gas and you can here it droppog revs then a person with knowledge is needed Thumbs Up
Post #598937 Thu May 14 2020 5:03pm
JohnBlueSport
Thanks might bite the bullet and take it to land rover,
Post #598940 Thu May 14 2020 5:21pm
Sham91
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Bonatti Grey
let us know of the outcome mate...seem to have a similar issue RRS TDV6 2010 Smile
Post #599081 Tue May 19 2020 7:41am
DrRob
Personally I would find an air con specialist in the first place. LR Main dealer will charge handsomely even before looking at it.
There are usually one or two air con specialists within 30miles of most people. Which is your nearest town/city?
Thumbs Up Visitor from fullfatrr.com
Post #599082 Tue May 19 2020 8:05am
