Home > General (L494) > L494 - Off Throttle Low Frequency Drone
PauloAmore
Scotland
Hi there,
I've noticed a bit of a drone noise when off throttle and slowing down. Not very loud at all...
- the sounds oscillates in line with speed... i.e. it slows as the car slows...
I'm thing diff or a shaft.
Think i should be worried? Preventive measures?
i previously had a diff leak that was re-sealed and filled...
Any thoughts and advice gratefully received. 2022 P440e AB
Post #594184 Sun Feb 02 2020 12:35pm
Will_127
I think I have a similar issue.
Present at low revs eg 1200 both in neutral and when driving. Mild vibration through steering wheel.
Took it in, they couldn’t hear it and said it was probably supercharger whine (which I don’t buy).
Did you get anywhere with yours?
Mines RRS 5.0 v8 sc 494 my17
Post #598782 Sun May 10 2020 11:43pm
gtr_skyline
So totally may not be the issue but I had something similar and looked under the passenger side front wheel arch and a large tree branch had wedged itself inside.
Prashan MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian
Post #598786 Mon May 11 2020 8:53am
scrumps
I had something similar after the dealer fixed a diff leak under warranty in my last AB. Turned out to be the diff. Replacement diff fitted, and a rear prop shaft as they noticed it had started to throw grease. Final diagnosis after a road test was to run it on a ramp, wheels free and the technician listened under the diff and it was howling!
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #598795 Mon May 11 2020 12:36pm
Will_127
Thank you, much appreciated. I will get them to have a good look once I can actually get an appointment!
Post #599023 Sun May 17 2020 6:51am
