Home > Maintenance & Modifications > inner wing guard cover coming away from inner arch?
hairy
United Kingdom 2009 Range Rover Sport TDV8 HSE Zambezi Silver
Hi I have a 2009 rrs, v8. only 33k miles in immaculate. the rear inner wheel arch (black plastic) is coming away from the outer edge of the wing? anyone else had this problem and if so how did you fix it.
Pete
Post #598637 Wed May 06 2020 7:15pm
Advanced Factors
Site Sponsor
Are the trim clips missing?
https://www.advancedfactors.co.uk/exterior...2714-c.asp
 Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Post #598646 Thu May 07 2020 8:48am
Seatown
Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands
Do you mean the wheel arch edge protector, coming away like this pic or the large moulded inner wheel arch liner?
 2010 TDV8 - current - my first RRS, loving it so far......
2005 Cayenne S - handling defied physics and what a sound, so sod the mpg!
1995 Disco TDI- surprisingly reliable, shame about the peeling dash & other trim
Lots of other non 4X4's in between times.........
Post #598664 Thu May 07 2020 3:47pm
hairy
yes exactly like your photo, no clips missing just the very outer edge? What do you do to fix this?
Pete
Post #598711 Fri May 08 2020 2:52pm
Seatown
The fix is to replace the edge protector with a new one. I think the steel reinforce within the rubber corrodes and causes this. They are available as individual parts or you can get a set of four to replace all at once. A simple pull off and push on of the replacements. I think the part numbers are CLB500051-CLB500061. Around £70 for four bits of rubber!
However I understand that the set for the Freelander is much cheaper than the RRS parts ~ £54 and you end up with a couple of spare lengths as well. 2010 TDV8 - current - my first RRS, loving it so far......
Post #598715 Fri May 08 2020 3:50pm
hairy
thank you!!!
Post #598716 Fri May 08 2020 3:53pm
Yeah, definitely get the Freelander kit six lengths in it, as said cheaper than the Sport one's and exactly the same stuff, if cut the lengths carefully can can do the whole vehicle twice as they really don't last that long, or sell the unused bits on and recuperate some of the initial cost.
Post #598726 Fri May 08 2020 11:09pm
hairy
thanks for the info, do you happen to know the part number for the freelander kit?
Post #598727 Sat May 09 2020 6:05am
Eaters
I'm keen to hear about these as mine too need replacing. Having look around I foiund these which would seem to be the genuine RRS items:
https://www.ebay.co.uk/itm/RANGE-ROVER-SPO...1826424549
And I guess that these are the Freelander ones mentioned:
https://www.ebay.co.uk/i/264615804373?chn=...gLXnfD_BwE
Does it matter if its Freelander 2 or not? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #598728 Sat May 09 2020 7:48am
Robin, those Freelander 2 ones are exactly the same stuff you get more and £20.00 quid cheaper.
Post #598729 Sat May 09 2020 8:15am
Eaters
Thanks Col. That's great. I'll go for a set those.
Do I need to lift the body to fit them??
Just kidding Rolling with laughter Robin
Gone:
MGZTT 190 2.5
Post #598730 Sat May 09 2020 8:18am
Seatown
And a wee bit cheaper from these guys if you're not fussed about LR branded packaging.
www.ebay.co.uk/itm/LAND-ROVER-FREELANDER-2...2101393890 2010 TDV8 - current - my first RRS, loving it so far......
Post #598735 Sat May 09 2020 11:26am
Eaters
Thanks Seatown. Have already ordered. Just bit the bullet or I’d still be deliberating next week Very Happy Very Happy Robin
Gone:
MGZTT 190 2.5
Post #598737 Sat May 09 2020 11:57am
hairy
fixed?
I took off the two rear pieces that were looking un-sightly, washed them and dried them, un-folded them and put Gorilla double side tape on the inside edge, fitted back onto the car then just folded them over onto the tape works an absolute treat see photos.. Gorilla tape cost £5:99 and still loads of it left.
Post #598740 Sat May 09 2020 1:17pm
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Thanks gents, just ripped mine off and waiting for the delivery man to replace! 2018 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #598743 Sat May 09 2020 1:56pm
