Home > Technical > crossover pipe
garytheobald
crossover pipe
Hi Im rand new here and wanted to say hello, also could anyone advise as to what is approximate cost including labour to have a new crossover pipe fitted to a RRS? thank you so much any help is always appreciated, Gary
Post #598719 Fri May 08 2020 5:11pm
Disco_Mikey
Entirely depends how rusty/corroded the fixings are
It can be done in situ, without removing gearbox or lifting the body, but if the fixings are corroded, don't pass around. Either pull the gearbox out or lift the body
Post #598722 Fri May 08 2020 6:10pm
