Home > General > Smart Key Problems
rabcnesbit
Smart Key Problems
Hello all. Both smart keys to my Evoque (MY 2012) no longer work (do not open/close doors or arm/disarm the car). One of the keys never worked when I bought the car (second-hand recently) and the other worked intermittently (but now not working at all). I even changed the batteries to new ones but didn't resolve the problem. Took the car to my independent specialist who diagnosed no output from the keys. He found one of the keys had the lock button missing internally (the key that was not working to start with) and the other key (the one that was working intermittently until recently) circuit board showing signs of moisture damage (he suspects the previous owner probably replaced the key case with an aftermarket case which probably did not seal the inside properly). Anyway, his conclusion is that the car needs 2 new keys, which can only be done at a main dealer as it will also required KVM to be replaced and reprogramming. I am based in London and estimated cost is £900 (parts and labour)!!! Any tips/suggestions please? Thanks
PS. I apologise for posting this on the RRS forum. But for some reason, since I registered on the babyRR forum a few months ago, I have been unable to submit my posts. After I have composed a post and click the submit post button, instead of the post being posted, I get an error page stating SQL error etc. (I have attached a screen shot below). I have tried using different browsers, but still getting the same error! No idea what's wrong
 RRS 2.7 TDV HSE MY07
Post #598461 Sun May 03 2020 11:29am
Dave-t
Have a look over on Disco3, I’m sure there is a guy over there that has done something with keys Joined the X5 45e club
1994 Defender 90 300 tdi
Post #598462 Sun May 03 2020 11:32am
Dave-t
Here’s one thread, there are others
https://disco4.com/forum/key-reprogramming...ement+keys Joined the X5 45e club
Post #598463 Sun May 03 2020 11:33am
rabcnesbit
Many thanks Dave-t, I have had a look at the link you provided, and some other threads on the forum. Searching the web for replacement keys I came across some websites that the guys will come to you and replace/reprogram the keys, and speaking to them I was told I do not need the KVM to be replaced as suggested/required by Land Rover. Anybody had any experience with these websites/companies that will replace and reprogram your smart keys? Thanks RRS 2.7 TDV HSE MY07
Post #598526 Mon May 04 2020 1:20pm
