Home > General > boot tidy
jack.bauer
boot tidy
What do ppl use as an effective boot tidy that doesn't invade space too much?/I'm thinking some sort of net option? 07 TDV8 + BAS map
Post #432251 Sun Aug 03 2014 5:55pm
What sort of stuff are you storing? I keep things like jump leads, tow strop, tyre pump under the back seats. Lots of useful space under there. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #432263 Sun Aug 03 2014 8:05pm
Gargy
England 2009 Range Rover Sport TDV8 HSE Santorini Black
Try ebaying Range Rover boot tidy. Quite a few on there.
Post #432269 Sun Aug 03 2014 8:25pm
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
Under the base of the rear seat is where my incidentals go Thumbs Up
Also have a net spanning the rear seat backs to put things in to stop them rolling around in the boot
Post #432295 Mon Aug 04 2014 11:50am
B16JUS
i just use a nice bag from jd sport for most items to keep tidy
Post #432318 Mon Aug 04 2014 6:52pm
jack.bauer
Thanks guys
Mostly water, air freshener spray, quick detailing stuff like cloth n sprays, small tools, torch, etc 07 TDV8 + BAS map
Post #432401 Tue Aug 05 2014 5:23pm
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
I've just bought an Oasser car boot tidy. Can't fault it, fits great into the boot of the sport and doesn't foul the spare wheel cover. Really pleased with the quality, sturdy and plenty of room.
Post #598264 Tue Apr 28 2020 6:21pm
scrumps
I ordered the load retention rails and bar system in my last AB and this one.
Works brilliantly and adjusts in seconds no matter what you are carrying.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #598299 Wed Apr 29 2020 4:25pm
nil07
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
I bought net from eBay around 35£ N
E46 M3
X6
2015 RRS HSE dynamic
2018 RRS Autobiography
2019 SVR
Post #598322 Wed Apr 29 2020 9:00pm
Ash3
scrumps wrote:
Scrumps
Hi
Can that be retrofitted and can it be fitted in a 7 seater?
Probably not i expect.
Post #598325 Thu Apr 30 2020 12:01am
There used to be two different kits VPLWS0243 for the 7 (5+2) Seater and VPLWS0242 for the 5 seater if I remember correctly, but may have that the wrong way round. Load retention net is VPLMS0302.
Post #598326 Thu Apr 30 2020 12:43am
scrumps
Yes, I believe they can be retro fitted. A meccano job, replacing the load securing rings.
Look on Topix for the instructions.
Check the accessory brochure for part numbers etc, would be my recommendation.
I had them factory fitted as it works out cheaper.
Post #598341 Thu Apr 30 2020 10:21am
Post #598370 Thu Apr 30 2020 11:46pm
BigBen
Boot Tidy
I recommend these
https://www.amazon.co.uk/STAYHOLD-Classic-...B00GY2FBIO
Work well and very versatile. Put bits in a cardboard box and secure with these. Also find a cardboard box with Velcro strips stuck on base works.
Post #598389 Fri May 01 2020 10:15am
