Home > Technical > "Groaning" HDC |
caporajm Member Since: 25 Jul 2005 Location: Austin, MN Posts: 55 |
Yes it is normal. I was riding in the car with the product manager and this is how the hill decent works. It's a pretty sweet system offroad. Also, if you have the hill decent engaged you can control how fast you want to go by clicking on the positive or negative speed control on the cruise controll. RRS S/C Special Edition, Vesuvius |
Sat Aug 20 2005 8:15am |
Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916 |
Must admit the noise the HDC makes can be quite discerning, but it does its job really well. Its out there somewhere. Second V10 Treg on the drive at the moment. |
Mon Aug 22 2005 3:34pm |
Andrew Member Since: 16 Jun 2005 Location: Cheltenham Posts: 248 |
mine used to groan, as normal, but now it doesn't work since we had a message in the display "HDC Fault Not Available" this morning. Phone call on Monday morning......... |
Sat Nov 26 2005 8:35pm |
It should make a lot of noise as it operates the ABS and TC. Don't be tempted to drive with it engaged unless you are offroad and on a steep slope otherwise your brake pads will last about 24 hours! The local Land Rover Experience ran Freelanders with HDC on all the time until they found at the end of the 1st week they had no brake pads left and severely damaged disks on the front and worn out drums on the rear. It's definitely a toy for offroad and then only when it is really needed.
Sat Nov 26 2005 8:56pm |
Have just been over on the D3 forum Andrew and there are some postings about it over there........................... problem appears to be a common one and they recommend a trip to the dealer!
Sat Nov 26 2005 11:06pm |
Thanks Tim,
Sun Nov 27 2005 8:24pm |
