![]() | Home > Wheels & Tyres > 275 55 20 tyres |
andyslandy Member Since: 20 Oct 2019 Location: Chesterfield Posts: 142 ![]() ![]() ![]() |
Quick question, has anyone fitted this size tyre and if so what were your thoughts. Thanks in advance Andy. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
Not sure if they would cause any major issues but that is about 80mm larger diameter than the standard 275/40 x 20 reckon the speedo would be a bit out with that size though and might rub on full lock.
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1181 ![]() ![]() ![]() |
Lot of US/CA owners run this size with BFG ATs, no issues. |
Thanks for the replies guys, agree Col the speedo will be out by quite a bit but can set the Garmin to bong when speed limit is reached so problem solved with that one.
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Andy,
